Using saved sets
Many Vectorworks dialog boxes allow you to save the current settings so that they can be quickly applied again.
To use saved sets:
Open the object’s preferences or settings dialog box.
The top part of the dialog box offers options for saved settings.
Parameter |
Description |
Settings |
Displays the name of the current saved set; to use a different saved set, select it from the list of saved sets available for the object. Any set in the list with angle brackets indicates either a Vectorworks default set or a set that hasn’t been saved. For example, <Active Settings> or <Custom Settings> refers to the dialog box’s current parameters, which are not saved as a set. <COBie Defaults> is an example of a default set provided by Vectorworks. |
Save |
Opens the Save Settings dialog box to name and save the current parameter settings; the saved set is added to the Settings list |
Manage |
Opens the Manage Saved Sets dialog box, to rename or delete saved sets. Select a name from the list, and then click the appropriate button. When renaming a set, if the entered name is already assigned to another set, you are prompted to confirm that you want to replace the existing set. |
